would it be possible to power up any RB from a laptop solely by using a usb to 5V DC plug similar to the ones on this page:
http://www.dhgate.com/wholesale/usb+dc+jack+cable.html
Appreciate your feedback.
standard USB port is rated for 5V/500mA, i.e. 2.5W, so you going to need upconverter to 9-10V. It might theoreticaly work with small boards like RB750, but still i think it’s not enough power.
Hi, thanks for your reply.
Is it possible to buy such an upconverter somewhere on the internet or only build this oneself?
Thanks.
