USB to IP socket forwarding
Hello
I have an Amber Wireless 868MHz Transceiver Modul connected to the USB Port of a 411U Board.
I need a solution to forward all recieved data from the Amber Wireless Modul to a special IP and to transmit data on the same way in the other direction.
it should be handled in this way
  • 868MHz modul is receiving a message over the air
  • U411 open a socket connection to a IP and sends the received message
  • the server sends an answer message
  • U411 send the answer message over the 868MHz modul
a so to speak USB to IP forwarder ?
Is there any solution ?
It’s possible to do this with mikrotik ?
Thanx
TwentySixer
I do not think you can get data from USB device to the router (from your specific device).
