hi, i would like to onnect the RB to a USB WIFI, i didnt see any in the hardware supported devices list… has anyoe done this before?
thanks
thanks
you cant as USB wifi is a client device so it cant play a role of AP or use Ad-HOC peer to peer but i don’t think you can connect RB with wifi USB but i am not sure about the same may be try to search google ![]()
USB WIFI can be used as a client as well as AP,
i have it running under XP…
other suggestions?
Yeh,
I showes one to the boys that I wanted to use..
It is a high output 802.11N with Ext Ant con.
Would be COOL to put your router on the ground and only the radio on the tower…
