USe 2 gateway
HI how are you?
I Have 2 dsl line with different ip address
i want Redirect web traffic on gateway 1 and download item Like mp3 avi …
To gateway to
i think do this with patch and mark packet
then redirect packet to diffrebt gateway
Friend can you help me and explan to me how to config this with winbox
Thanks A lot
unfortunately, you cannot do that - as far as I know, RouterOS Proxy do not have such capabilities. I think you should use external Squid server
Thank For your reply to my question
i think USer Patch in mikrotik for select Format and mark packet The route market packet between 2 gate way
True Idea?
you canot set packet mark in WebProxy
I dont user web proxy roll for mikrotik .is gateway of my network
you need proxy feature to inspect http requests, so your choice is Squid
I’ve asked a almost similar question here: http://forum.mikrotik.com/t/traffic-splitting-with-address-lists-and-transparent-proxy/34660/1
In my case I’m just using the transparent proxy for the more expensive WAN connection. Ideally I would have to use a Squid proxy like Chupaka said. I thinking more and more that this option would be better, since my RouterOS 4.5 isn’t caching the content at all.
