But since the FW 6.2 released, the script seems to be incompatible with the FW 6.2.
Knows anyone why? Thank you for any help:)
I mean this script:
/system script add
name=resolvehostnames policy=write,read
source=“# define variables\r
\n:local list\r
\n:local comment\r
\n:local newip\r
\n:local oldip\r
\n\r
\n# Loop through each entry in the address list.\r
\n:foreach i in=[/ip firewall address-list find] do={\r
\n\r
\n# Get the first five characters of the list name\r
\n :set list [:pick [/ip firewall address-list get $i list] 0 5]\r
\n\r
\n# If they’re ‘host_’, then we’ve got a match - process it\r
\n :if ($list = "host_") do={\r
\n\r
\n# Get the comment for this address list item (this is the host name to u
se)\r
\n :set comment [/ip firewall address-list get $i comment]\r
\n :set oldip [/ip firewall address-list get $i address]\r
\n\r
\n# Resolve it and set the address list entry accordingly.\r
\n : if ($newip != $oldip) do={:set newip [:resolve $comment]\r
\n /ip firewall address-list set $i address=$newip}\r
\n }\r
\n }”
The problem seems to be with the line:
:if ($newip != $oldip) do={...It wouldn't work for me using either != or =, not sure what's going on with that, but then I noticed the script doesn't make sense at that point anyway. $newip will never equal $oldip, so it will always resolve the address and it set the address list even if the IPs has not changed.
:if ($newip != $oldip) do={:set newip [:resolve $comment]
}I fixed that problem, and then it was working on v6.2. This script resolves the address for each one, but only changes the IP if it's different.
define variables
:local list
:local comment
:local newip
:local oldip
If they're 'host_', then we've got a match - process it
Get the comment for this address list item (this is the host name to use)
