And your average peak hours usage will be like 500-550Mbps download and 500Mbps upload, as we sell our upload to a some mini data center clients.
We need all 3 ISP feeds to be simultaneously and the packet request should automatically choose which WAN has the best latency, and it should automatically choose path.
We already tried PCC, but it doesnt choose the best path, so we have to force a particular WAN for upload. Is there a way, we can make the settings that mikrotik takes the best path for upload ??
Unfortunately I don’t have such relevant experience with this type of load balancing but I saw some kind of metered approach here on the forum that should measure the actual throughput of the wan links and set the ratio according that. Search for it. Maybe you would need to make some tryouts…
Its behavior was more like: fill up link 1 then use link 2 if link 1 is full, then use link 3 if links 1 and 2 are full.
It’s a little different than you want, perhaps, but in the end it gets the same effect - to load balance differently-sized internet connections proportionally.
