Hi, I has several APs working with NV2 protocol…
Is a good idea use this protocol? I read that with interference enviroments it don´t work well… Is a better idea to change to WPA2 protocol?
Thanks!!
Thanks!!
NV2 is a wireless protocol and WPA2 is a security protocol…
You cant compare these too…
For more details about Nv2 read here https://wiki.mikrotik.com/wiki/Manual:Nv2
Hi, yes, you’re right… but who has better performance … and with noisy environments ?
Thanks!!
Not Nv2, however i would suggest you try it…
Else, 802.11 is the protocol you should use…
Hi, thank you so much, I´ll test 802.11 WPA2, in the past I´ll using NV2 but some links when rain drops a lot the CCQ…
Thanks a lot!!
I think you mix 802.11 and WPA2… completely different things as Zacharias pointed out.
