Hi there,
I’m using RB2011UiAS-2HnD with RouterOS 6.13 and latest firmware.
I’ve noticed that it can turn on (on ether10) some devices. I used it with a SXT Lite5 and a Ubiquiti device.
I’ve noticed that RB2011UiAS-2HnD could not turn on RB OmniTIK U-5HnD.
Is it correct?
Yes I’ve experienced the same when using ether10 on the RB2011UiAS-2HnD to power up my OmniTIK UPA-5HnD.
BTW, I’m now using the UBNT Toughswitch to power up the OmniTIK and it works.
Hi and thanks for your answer. Did you experienced this problem with other devices too?
No, just the OmniTIK.
I’ve tested and confirm that these devices can be powered from RB2011UiAS-2HnD ether10 :
- UBNT Unifi-AP
- UBNT Picostation M2-HP
- UBNT Nanostation loco M5
- EnGenius ENS200EXT (must be set to forced-on, auto-on doesn’t work)
I also used RB2011UiAS-2HnD to turn on BaseBox5 (RB912)
