I’m trying to implement some sort of policy routing by using connection- and routing marks in order to return incoming traffic on the same outbound path. Basically I’m having two upstreams ISP A and ISP B, which both send me a default-route via BGP.
ISP A is main-uplink (local-pref=200 and no bgp prepend) and handles most in- and outbound traffic.
ISP B (local-pref=100 and bgp prepend) is mostly for fallback and only has very little inbound traffic.
Now I would like to force all inbound traffic coming from ISP B to return back outbound via ISP B route and not via ISP A. All other outbound traffic should be routed via ISP A. The reason for this is that ISP B has a better route for a few, directly connected networks, but which have a very bad route over ISP A. Since I only receive default routes, obviously my router can’t make routing decisions himself. For now I do not want to add those affected networks to my routing table manually nor I want to switch towards receiving a partial or full table by on of the two ISPs. So the only feasible solution would be some sort of policy-based routing.
Somehow it seems I can’t get this working, even after looking at a few other examples here on the forums. Running on latest ROS 6.40.1.
Is there something wrong with my mangle rules or am I missing something else?
Thanks in advance
> ip firewall mangle print
chain=forward action=mark-connection new-connection-mark=ISP_A passthrough=yes in-interface=eth1-isp-A log=no log-prefix=""
chain=forward action=mark-connection new-connection-mark=ISP_B passthrough=yes in-interface=eth1-isp-B log=no log-prefix=""
chain=prerouting action=mark-routing new-routing-mark=transit_ISP_A passthrough=no connection-mark=ISP_A log=no log-prefix=""
chain=prerouting action=mark-routing new-routing-mark=transit_ISP_B passthrough=no connection-mark=ISP_B log=no log-prefix=""
chain=output action=mark-routing new-routing-mark=transit_ISP_A passthrough=no connection-mark=ISP_A log=no log-prefix=""
chain=output action=mark-routing new-routing-mark=transit_ISP_B passthrough=no connection-mark=ISP_B log=no log-prefix=""
> routing filter print
chain=isp-A-in address-family=ip invert-match=no action=accept set-routing-mark="transit_ISP_A" set-bgp-local-pref=200 set-bgp-prepend-path="" set-bgp-med=0
chain=isp-B-in address-family=ip invert-match=no action=accept set-routing-mark="transit_ISP_B" set-bgp-local-pref=100 set-bgp-prepend-path="" set-bgp-med=0
> ip route print
0 ADb dst-address=0.0.0.0/0 gateway=A.A.A.A gateway-status=A.A.A.A reachable via eth1-isp-A distance=20 scope=40 target-scope=10 routing-mark=transit_ISP_A bgp-as-path="65534" bgp-local-pref=200 bgp-med=0 bgp-origin=igp received-from=AS_ISP_A
1 ADb dst-address=0.0.0.0/0 gateway=B.B.B.B gateway-status=B.B.B.B reachable via eth1-isp-B distance=20 scope=40 target-scope=10 routing-mark=transit_ISP_B bgp-as-path="65535" bgp-local-pref=100 bgp-med=0 bgp-origin=igp received-from=AS_ISP_B
