i wanna bond 2 wireless links , i’m gonna use RB435GL
is that possible use RB435GL for 2 XR5 mini-pci card and for bonding setup ?? enough ram? enough CPU power ?
i don’t want to buy 2 another router for each side , any help
Thank You
Thank You
It should be just fine. All depends on the load on the links, as well as routing protocols (OSPF, BGP, Conn tracking)
You should go for RB800 as foresee you looking for high bandwidth… ![]()
Sent from my GT-I8190N
