use set x,y,z after print where possible?
i want to replace at my router an gateway for many prefixes..
Now the Router has about 100 Routes.
Now i will replace the static route to 72.80.1.0/24 with easy in CLI.
i make
pr where distance =1 , it counts 0,1,2,3,4,…
is it possible, that after this command is to use set 0,1,2,3,4 gateway=x.x.x.x ?
I mean, is the set of 0,1,2,3 in the “set” command after the “print where” command possible, or will set this another routes (that will should com as i has used normaly “print” command???
Sorry, beginner question :slight_smile:
Christian
