Use the Audience as a bridge
I was wondering if I can use the Audience as a wireless bridge connected to an existing home network.
There is a drop down menu on Audience quickset menu with various access point option among others but was told by the dealer that it can be used as a wireless router or mesh with a secondary unit.
Really appreciate assistance/advice.
Thanks.
Quickset is only a Tool to help configure basic Network-Setups.
You will need to Configure the Wireless-Bridge manually in WinBOX.
The Mikrotik Audiance has 3 Wireless-Interfaces and 2 Ethernet (10/100/1000)
You can pretty much config it, any way you can think of !
If you Draw or Tell us how you want it, we can help you with the Configuration.
