use the same configuration on other mikrotiks
Is it possible to use exactly the same configuration of a mikcrotik device on other mikrotik devices?
I try it with /export name=config but than are the MAC address of that device in the file. If i use this in an other devices than it is not working and i’m missing things.
So is thare a good solution???
Try using /export compact instead of just /export
