Use usermanager on same radius client router
I hope my question is not dumb,
I have a mikrotik router (v7.3.1 on x86) that I am setting up the ikev2 method with user/pass authentication via EAP. The problem I have is that we need a RADIUS server to perform authentication. I wanted to know if it is possible to use the same router that has the role of RADIUS client as its own RADIUS server? I mean that it authenticates ikev2 users through its own usermanager.
I hope I was able to get my point across. thank you.
I expect it to work via address 127.0.0.1.
There is already a default accept rule in the firewall intended for CAPsMAN : “defconf: accept to local loopback (for CAPsMAN)”
The rest should be the same as for any other RADIUS client setup:
  • add router 127.0.0.1 in User Manager , with a defined shared secret
  • add link to RADIUS server in “RADIUS” , with IP 127.0.0.1 and same secret
  • check firewall rule for 127.0.0.1 for input allowed
