User access control
hello all
i have setup 2 PPPOE internet connections on 2 different ether(1,9). and i set up GRE tunnel to another Mikrotik router which uses PPOE1, and then made a mangle to separate internet requests and force them to pass through the second PPOE connection , Now I want to grant Internet access and control users usage for only authorized users.
how can I apply a hotspot without changing IP address of the connected client and then redirect to the hotspot login page without affecting connections on PPOE1 and .
I found a solution.
for someone who may be looking for :
Try to enable Hotspot with manual setup (don’t use hotspot setup configuration) and leave ip pool empty. In this way, client IP addresses remain the same when clients are logged to the hotspot server.
remember to configure the server profile as well manually.
Hello!
Could you please share how did you configure the mangle rules to redirect your PPPoE client to the Hotspot? Also, may we know what ROS version you are using.
Thank you.
