User delegation
Hello Everyone,
Is possible to create user which only will have access to Wifi security profile to be able reset Wifi password ?
Nope. And it’s annoying that you cannot separate that out.
The Wi-Fi password is considered “sensitive” policy, so that means it can change ANY password beyond Wi-Fi PSK. And while you can restrict it SOMEWHAT using skins and customizing the policy to say only allow webfig for a user. But at the end of the day, skins ONLY HIDE, but the user still has right to change write sensitive (if you want to user to be able to set their Wi-Fi password themselves).
Thank you for reply,
Yes, need figure out some API web hook.
Hopefully in future it will be more flexible.
