I’m brazilian, then I don’t speak english very well, forgive me for that.
It’s my first post in this forum, I’m a beginner in the Mikrotik, and I’m seeking for help.
I has instaled a RouterOS v 5.22 in Dell T210, like a BGP. But, users settings are lost some minutes after configuration. Just user settings are lost, routes and firewall settings remain intacts. I don’t know why.
How do you connect to the router, and which configuration did you apply specifically? How did you determine that user settings are lost? Which configuration method did you use, and what command did you enter?
I connect to router by winbox. I use the menu System-> Users to add a user. I create a user, I define username and pass, but after some minutes, trying login, winbox shows “wrong username or pass”. I enter again, using user admin and pass empty. In Sytem -Uers, there are not other users, just admin user.
The bug you are facing, is different. The window where you create the new user, is ignoring the password input. This is fixed in newer RouterOS versions. You can work around the problem by adding the user with no password, then opening it for editing, and adding the password then.
