User Manager and VRRP
hallo,
i want to use User Manager on 2 routers which because of failsave are one vrrp-router.
is it possible to use and configure usermanger like on one normal router? or have have I to configure usermanager on both physical routers with the same settings?
it would be perfect if I could connect to the vrrp address and make my changes in usermanger an both physical router have the settings stored.. is this possible?
thanks in advance!
It is not good idea to use User Manager on VRRP router.
I suggest you to move User Manager a bit further in the network, on the gateway of the VRRP routers, or set it in the local network.
VRRP is almost impossible as there is no synchronization between to User Manager routers.
Ok.
Thank you sergejs for your answer!
