User Manager "Client" Cant Login By PPPoE
Hey Guys,
Please help me. I am newbie on mikrotik. I have setup each configuration with proper settings for user manager. When I am going to access internet by PPPoE, some error is showing up. I took a screen shot and upload here for your better references. Please help me to solve this problem.
Kawsar
Under winbox:
Ensure you have servers specified under PPP->PPPOE SERVERS
on the SECRETS tab
PPP Authentication & Accounting → Ensure Use radius is selected and interim update of your choosing , I use 00:30:00
Which updates every 30min.
Radius - Ensure you have an entry pointing to your usermanager box
service select ppp if using hotspot as well select hotspot
Address: ip of your usermanager box (if it’s all on one box use 127.0.0.1)
Shared secret the same as what is defined in user manager router section (IP should match the ip of defined router as well)
http://wiki.mikrotik.com/wiki/User_Manager/4/PPP_Setup
