i have a routerboard ( hap lite RB941-2nD ) and i want to install user man. on it.
pls…Help Me..
not possible. not enough memory and cpu power for user manager.
hap lite is intended for home use.
Hello Aminzakeri,
The hap lite routerboard series does not support userman. As an alternative I suggest that you use The Userman application. This application can generate user, time limitation and print a simple hotspot voucher. More information please visit this address http://theuserman.blogspot.co.id/p/tentang.html
you can use external radius server or online user manager.
try using http://www.ebss.cloud
i dont see the point paying fees per month to on line radious services than buying a better mikrotik device like rb951 (level 4) or rb2011 (level 5) for usermanager.
Mikrotik Userman is simple and does not have many features.
by using cloud radius in addition to initial facilities you get many features like SMS based authentication, polling system, configuring and design hotspot login page and …
Hello, I found this incredible app for android is called MikroTicket https://fhx47.app.goo.gl/mikroticket generates tickets or vouchers for access by hotspot mikrotik and you can configure access times, bandwidth, time runs and makes automatic removal of the vouchers, I use it in my business. https://youtu.be/DZqg4BIMEUw Regards
Sir I tried to do that. But I currently getting a “This password is incorrect” error. How do we fix this?
