hi
how to use “keep alive timeout” in user manager?
up
up
no help>>???
please explain more what exactly do you want to do
I have the same problem as acimas friends, I am using a rb1100x2 and abilitei usermanager the radius and then when the client is connected and the link happens to drop it off or the equipment that is connected to my network, so does usermanager the keepalive-timeout that is not tipping User session so when he turns on the equipment again unable to log in because it already has in this User session stuck.
We need an urgent solution …
It’s happening the same to me. Any solution?
And It’s happening the same to me.
How to set different keepalive timeout for 2 hotspots, which use the same userman for authorizing users?
I try find keepalive in user manager and dont have succes.
in your hotspot user profile the default profile is using for all users in user manager
if you want to use more of profile for example you want use diffrent keep alive timeout for every profile in user manager
you need to use group name in profile limitation to join it by profile in hotspot
