User Manager not works with redius
I have Hex Lite router with 6.33.5 router OS.
This is my addresses segment:
The Hotspot works correctly and users in Hotspot can login and then access to Internet.
But my radius not work and when i click over it, just a shadow of record shows up and i can not edit it.
This is an image when i click over radius:
Also User manager not works and my client can not login with defined users in user manager. My client just can login with defined users in Hotspot segment.
This is my router configuration in user manager:
and this is error when my clients try to login and access with a defined user in user manager:
Ok Try this,
I found some funnyness when using 127.0.0.1.
Usermanager is not properly talking to the radius.
Create a bridge , with no ports and give it the address of 192.168.89.1/32
Change the ip address in the radius and userman to that.
It solved my issue
