User Manager + Other Applications
Hi
I’d like to know if it is possible to let Linux’s poptop server auth against User Manager using the normal linux radius client - and on what ports, if other than the normal Radius ports, does User Manager listen on for incoming requests.
Thanks!
Krige
Krige, we have not tested it with Linux RADIUS client.
It might work, however we did not tested it. Note, that your client should able to recognize attributes provided by the User-Manager.
Thanks for the heads-up.
I’ve noticed that under /ip/services, there are no ports being listened on that resembles a Radius engine. What port does User Manager listen on for incoming requests?
-Krige
There should be default ports,
authentication-port=1812
accounting-port=1813
