Hello
i am getting this browser warning both in Firefox 2.0.0.4 and Internet Explorer 7 when i logon to the user-manager web interface and when navigting the user-manger menus
Stop running this script?
A script on this page is causing Internet Explorer to run slowly.
If it continues to run, your computer may become unresponsive
Yes No
when i click "No" pages take eternity
to load and displays the same error again.
when i click "Yes" pages loads. this is very regular when i create customer accounts with less permissions than owner.
please what might be causing this. i was running version 2.9.43 but i upgrade to version 3.0beta9.
regards
I have running 2.9.43 and I don’t have this problem. The mistake are posible for the update at v.3 from 2.9.43.
Regards,
Fran.
Well i wass having this problem in version 2.9.43 so i upgraded to version 3.0beta9 hoping problem will be solved but still same script error warnings
be grateful if any lopp holes causing this problem could be pointed out
regards
Well, my MT run well and there was no problem at all, maybe you should check the setting!! It maybe better if you cross check your userman setting with the manual
yes i recreated the thread on this problem again earlier
http://forum.mikrotik.com/t/user-manager-reports-script-delay-when-credit-vouchers-are-c/14070/1
one of the gurus informed me it was a unicode character ¢ of my currency symbol which was not supported.
regards
