User-manager
I'm trying to get User-manager web access. No luck.
I'm running a hotspot. briefly, Do I need to disable all hotspot users first to enable user-manager?
I keep getting:
"This error (HTTP 501 Not Implemented or HTTP 505 Version Not Supported) means that the website you are visiting doesn't currently have the ability to display the webpage, or support the HTTP version used to request the page.
I've enabled a subscriber. I've read that's all that's needed to enable web-access to user-manager via http://router_ip/user-man.
Here's the basic config. I have user-manager enabled in the running "hotspot5 profile".
I don't think this is correct.
[admin@MikroTik] /ip hotspot profile> print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name=""
html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap
http-cookie-lifetime=3d split-user-domain=no
use-radius=no
1 name="hsprof1" hotspot-address=10.10.0.1
dns-name="login.hotspot.com" html-directory=hotspot5
rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=http-chap,trial split-user-domain=no
trial-uptime=2h/1d trial-user-profile=default
use-radius=yes radius-accounting=yes
radius-interim-update=received
nas-port-type=wireless-802.11 radius-default-domain=""
radius-location-id="" radius-location-name=""
radius-mac-format=XX:XX:XX:XX:XX:XX
OK, WEIRD...
The problem was. I was typing http://router_ipaddress.com/user-man
instead of: http://router_ipaddress.com/userman
I was getting a web-page with the hyphen between user and man.
But couldn't get past there!!!
This is either an HTML bug or what the FU
&^ over?
