I download user manager, and installed it, but it is not showing under tools.
Im I doing anything wrong
Thank You
Thank You
You have to ensure, that ‘user-manager’ package is enabled (check ‘system package print’).
And (if this hasn’t changed in the very latest version) know that the user-manager can only be configured from the terminal/console, not via WinBox (until now).
Best regards,
Christian Meis
You have not done anything wrong besides looking for it in the wrong place. I had the same problem and since there is no manual yet I had to try figuring it out myself.
To use or configure User manager you can’t use the winbox software. Use your browser or terminal/console to check or configure the user manager
The browser to me has a simpler feel
The url is http:// your mikrotik IP/userman
Victor ![]()
Virene,
very short description about statrup User manager configuration.
Hi victor,
That's program [UserMANAGER] under contruction i thing, i hope next time MT will make to easy configuration just with MOUSE [next generation], now from this time i has radius server hotspot under UserMANAGER package, try it .... that's true.. and very nice see interfaces to radius......cool....enjoy....relax
Using user manager the first most important thing is to setup an account. This is because mikrotik user manager doesn’t come with any account. Use Mikrotik terminal (console) or telnet to connect and setup an account.
From the default prompt, type tool user-manager customer and than enter
Type add and enter, Login appears
Type the account Name and than enter.
[admin@MikroTik]
Type “tool user-manager customer”
[admin@MikroTik] tool user-manager customer>
type add
[admin@MikroTik] tool user-manager customer> add
And new prompt appears
login:
type the use name (admin account) and then enter
You can check to see if the account was setup by doing a print from
[admin@MikroTik] tool user-manager customer> print
0 subscriber=admin login=“admin” password=“” time-zone=+00:00 permissions=owner parent=admin
Use can now use the user manager (web interface to login with the new account)
That all folks
Victor
yes, you can use it at 'http://Router_IP/userman' and login as manager with 'username=admin' and 'password=empty'
but, before do it make sure for '/ip service set www disabled=no'
and do it..
....and..and..and.. create users from that web interface
