Hello
When i press disable in the usermanager, how is the disable process, because if i disable an user the internet keep working on that particularly user, or how many time takes for remove it?
Hello
yes, user is working, it will stop working, when user would disconnect and try to connect again.
You can manually remove that user from HotSpot to stop operation immediately.
Thanks For the Answer
but there’s a way that i could preform like a script for remove all the clients, for 3 sec, and re-connect again for all the clients disable on the list don’t re-connect back.
Currently there is no automate solution.
But we are working on adding radius incoming feature for User Manager, when Manager sends disconnect request for the appropriate client, but currently it’s not possible.
