RedHat
You have to create script, that will force clien to ‘relogin’ to HotSpot once more, if you wish to achieve the described scenario.
However, ‘queue simple’ provides matcher ‘time’, that allows to create ‘queue’ per time, set two static ‘queues’ with ‘time’ option (then you won’t need any script to change ‘users’ bandwidht), limit will be applied immediately at time.
could u tell me what is the scripts that make me able to log the user off and make theme then logging in in there profile ??
how could i make this script !
