Halo, I’m looking for a way to execute this option. My user will get good browsing speed but they will get limited download speed. My isp bw get saturated because of that, user do not get good browsing. I thought about burst limit but i think that will not help. Can anyone share their experience about how can i do this?
One way to do it would be to setup QoS and then mark any connection that has, for example, over 5mb of traffic and place that connection in a lower priority queue.
You mean marking http traffic above the que and select unlimited bw and then make qus for user with limited BW?
No. I mean it like I said it. I will try to find an example in the morning.
Dear Forum Guru, it would be very kind of you if you discuss on this issue and also give a perspective over burst limit. My issue is i can not let my user to use bw of lower than 512kb. I want them to get 512 browsing speed but their download speed will be like 340kb. is that possible?
can use user profiling at limitation section…
far…far away…from the Land of Hornbills
even can set minimum bandwidth and maximum bandwidth for you client/user… ![]()
