Userman Bandwidth on Shared hotspot users
Can someone help me with this?
using version 6.29
3 users are logged on the hotspot with the same username and they all get the maximum bandwidth each…
how can i make 3 users share the allocated bandwidth?
Sorry, you can’t
You force equal sharing amongst all hotspot users with Queue Tree and PCQ. Is it a public hotspot?
Add ip pool specifically for that user. then limit the bandwidth for the pool manually via simple queue
i tried it works… but when the user log out and log in again the user will have full speed again…:frowning: i have to manually delete the dynamic queues for that user…
is there any workaround with this? thanks for your reply!
First, add a new ip address (different from existing ones) on your ether-hotspot .
Add ip pool for the new ip. then limit the new ip/24 on simple queue manually.
create a new hotspot profile with the new ip pool you just created then use the profile for that user.
its still the same… when the user log in, it automatically creates dynamic simple queues and overrides the static queues…
the hotspot profile for that user must be unlimited . so your manual limiter on simple queue will be work.
