Hello!
I have a mikrotik hotspot that uses the radius with the UserManager to manage users.
use the version of the UserManager 5.x
the problem is this: the users of the database has lost the limitation on, and I need to go to reset to reactivate the profile for each user.
I found this:
/ tool user-manager user create-and-activate-profile name = “” customer = “” profile = “”
I can not find the way to do qesta operation for all users in one shot.
Thanks to all
Lele
Hi
I had the same issue i had to transfer PPP Secrets to Userman.
It was easy to export the Users into a file and then use a text editor like textpad to replace the differences and then get all the users onto userman.
I got it to work i again exported the Secrets into a file but this this using hide-sensitive that enabled me to again use textpad to Replace the text so at the end i had a hole list that i just copied and pasted into my terminal
create-and-activate-profile profile=Glen customer=admin user=ManyashaS
create-and-activate-profile profile=Glen customer=admin user=MatthysW
create-and-activate-profile profile=Glen customer=admin user=Nthabiseng
Etc…
