How to create working config, for using with DHCP clients, on wired lan
any one to help
try to communicate your Radius Client with Userman first..
then give each of your user a different username-password that u had added in Userman..that will do the work ![]()
Probably, the following example will help you to use User Manager for DHCP leases,
http://wiki.mikrotik.com/wiki/User_Manager/DHCP_Example
Is this posible to one Pc, 50 users behind
version: “2.9.27”
free-memory: 60392kB
total-memory: 95344kB
cpu: “AMD-K6™”
cpu-frequency: 450MHz
cpu-load: 17
free-hdd-space: 1939020kB
total-hdd-space: 2019544kB
P.S.
I split, and need to split after local from overseas traffic
any help please
Local and overseas traffic limiting example is given in the wiki,
http://wiki.mikrotik.com/wiki/How_to_apply_different_limits_for_Local/Overseas_traffic
if you have any other questions about queues/mangle, you can ask it in the ‘General Networking’ section.
I split long time ago, but howto split with Userman
I suppose it is not possible, you need to use mangle and queues on the router to accomplish the desired scenario.
