Userman Hotspot
Dear all I have the following Problems.
  1. I have install Userman on Mikrotik with hotspot. My problem is when i create a user and am login to one device if i use the same code on another device is kick out my first device from internet and connect to the second. I want my code to be used only in one device, and to not be able to connect to another by take the internet from the first device..
    i have checked everything shared users also on Mikrotik shared user and is correct.
  2. My second problem is that if my code it has limit for 1 week and connect after 2hours or 2 days is opening the logon page again . why is not keep my device saved so for 1 week do not open the logon page again until expires.
Thank you very much!!!
For your second question use cookie or mac cookie
