Good day,
I have set up a working hotspot with userman and radius authentication.
The issue now is the vouchers.
If I understand correctly there should be a pop up window when you click generate voucher.
When I click it nothing happens.
I tested on a local router, but still the same happens.
Is there something specific one should set up or should it just work?
Thank you.
