userman not working?
Where can I find documentation on userman.
I downloaded and installed user-manager-2.9.23.npk.
I went to http://192.168.2.250/userman
I cannot logon.
I have tried admin with my password, admin with no password… what am I missing. Where is userman in Winbox or where can I get some documention on setup and use???
:confused: Travis
Search the forums. There’s a description of the command to add user accounts to access the user manager (sorry, don’t have it off hand). The user accounts used to authenticate are NOT the normal RouterOS accounts. And there are no default accounts, you have to CREATE at least one first!
Best regards,
Christian Meis
i looged in … BUT … only the left frame is on !!! nothing on the right side , nothing working but the loggout !!!
It’s weird. Userman works fine for me.
Have you try to open it on different browser?
what browser are you using ?
firefox and ie are working
opera does not !!
opera works fine! upgrade your browser. tested with opera 9
go to the menu
/tool user-manager customer add login=yourname password=yourpassword
the use the new yourname and yourpassword to login into the userman page
jolly.
