I’m using UserMan, PPPoE and fixed IP address with my customers.
I want only one Username can login at a time.
What do I need to do?
i guess it would be simple but not that easy..
the solution is to give each one of the user a password.
For MT Crew:
But for me it got to have 2 layers security login..
password as the first layer, then MAC authentication as the second layer..
is it possible to do this in UserManager?
Thanks ![]()
ya,… ![]()
Hi jahwara,
I do have User/Pass, how do I implement Mac auth?
Thanks,
AsDsL
There are different methods to authenticate in the HotSpot, one user/password, second MAC authentication. I think you can use them separately now.
In the other hand using regular HotSpot without Manager, it is possible to accomplish:
- use standart login/password authentication;
- specify MAC-address for the users, ‘ip hotspot user set user_name mac-address=XX:XX:XX:XX:XX:XX’, only user with the specified MAC-address will be able to use the particular username/password.
For Future Feature Request..
The UM got to have 2 layers security login..same as what MT crew have implemented in the hotspot feature…
It would be just…Awesome
Thanks ![]()
