Userman + PPPoE Issue after update
Hi all
My pppoe customers are not reconnecting after updating to 6.47.1. Seems like their IPs are being blocked or something… IPs in lower range eg. x.x.88.102-150 are not working while the range x.x.88.201-250 are.
If I change their IP etc it connects. Also seems like Userman is corrputing?
Any help?
Thanks.
So I stayed on old firmware to avoid the problem… A few days ago I needed to replace my MT and the oldest firmware for it was one that reproduced this problem.
After digging and digging I noticed that the problem was that when a PPPoE user lost connection due to reboot or power failure etc, their dial in remained “active” in userman sessions. Thus causing a new radius connection being unable to authenticate…
I finally found this solution posted by a fellow user which solved my problem after SO long!
“Remove false active sessions via script”
viewtopic.php?p=918297#p918297
:local LastSessionUpdate;
:local SessionTimeout;
:foreach i in=[/tool user-manager session find where active=yes] do={
# When was the last Update of the session-informations
:set [/tool user-manager session get $i till-time]
# SessionTimeout is a value that tells me how many seconds ago the last update of this session was
:set ([system clock get time] - [:pick $LastSessionUpdate ([:find $LastSessionUpdate " "]+1) [:len $LastSessionUpdate]]-[/system clock get gmt-offset])
# if last update is more then Timeout seconds ago then close session and log it
:if ($SessionTimeout > $Timeout) do={
/tool user-manager session remove  numbers=$i
:log warning (" Removed false active session by Zaib - Username is  " . [/tool user-manager session get $i user]);
