Hai. I have also noticed that the Usermanager doesn’t disconnect users when the profile validity is over. If you log off and try log in again it works if validity is over. But if one doesn’t log off the machine then he can even use it for 2 months wishing power never goes off.
This should be checked by MK.
this problem is still existing.
I want to make a hotspot where logins are valid 24h.
I have tested it with 30 min validity, but you are not logged out when 30 min are over.
when maually removing the hotspot user in winbox, the expired user cannot logon anymore. but this cannot be the way that was ment to be done.
I have created a 100 MB download users. After the user downloaded 100 MB is not automaticaly disconnected from router, and can download how much it can. If the user logoff then the manager is not alowing to reconnect.
How can I setup the hotspot that user manager see when a client is reaching the download limit and automaticaly disconnect him?
