From the Wiki. LOOK CLOSELY AT THE TEXT IN RED BELOW, THE ORDER THAT YOU IMPORT IS VITAL. FOLLOW THESE INSTRUCTIONS CAREFULL AND IT WILL WORK.
HTTPS connection enabling
[edit] Creating certificate
Trusted SSL Certificate can be bought from trusted authorities, for example, VeriSign. An unsigned certificate can be generated by hand, using OpenSSL on a Linux box. To do it issue following commands in the shell:
openssl genrsa -des3 -out server.key 1024
openssl req -new -key server.key -out server.csr
openssl x509 -req -days 365 -in server.csr -signkey server.key -out server.crt
Two important things:
- Enter the same pass phrase always when asked for “Enter pass phrase for server.key” (Should be 4 times);
- Enter your server’s domain name, when asked for “Common Name (eg, YOUR name) ”. This is important, because otherwise some browsers may refuse your certificate. For example, if the User Manager server’s address is http://userman.mt.lv/userman, then “userman.mt.lv” must be specified as Common Name for the certificate.
After doing this three files will be created:
- server.crt - Certificate, must be uploaded to router;
- server.key - Private key, must be uploaded to router;
- server.csr - Signature request, can/should be deleted;
[flash=]Upload server.crt and server.key to the router and import them, using the same pass phrase again when asked. server.crt must be imported before server.key.[/flash]
[edit] Importing certificate
Certificate file can be then uploaded to the router and imported with command
/certificate import file-name=…
The command should return
certificates-imported: 1
private-keys-imported: 1
files-imported: 1
decryption-failures: 0
keys-with-no-certificate: 0
If it doesn’t, could happen that the file contains private key and certificate sections in incorrect order. In this situation the output should be
private-keys-imported: 0
files-imported: 1
keys-with-no-certificate: 1
Just repeat the same command
once again and the output should be this time
certificates-imported: 0
files-imported: 1
Now certificate is imported correctly and ready for use;
