Usermanager 3.23 Problem with correct time in the logs
HI,
I have a ntp-time server with the correct time on my Mikrotik with usermanager, but in the logs of the Usermanager the time is always 2 hours back.
Have somebody any Idea?
And how can I delete all of my 260000 Logs at one time?
Thx
  1. You may specify time-zone for /tool user-manager customer to get the correct clock.
  2. The only way to delete all the logs at once by the command,
    /tool user-manager log remove [find]
    Console can return timeouts, but you should wait plenty of time to delete all logs.
THX
And how exactly to do this?
which parameters i have to put in to set my Usermanager time?
Or can you provide me with a link to the documenation for setting up time to usermanager?
thank you
Sorry,
I have found it out.
I do it directly in the user manager console under customers.
Thanks anyways
