Usermanager and Hotspot: Lock voucher to MAC address
I am using User Manager with Hotspot and it is working great! One featre I would like to have though is the ability to lock a voucher to a MAC address the first time it is used, so that the voucher cannot be used from a different laptop once it is activated.
I am hoping it would not be too difficult as this is exactly what the trial usage does - I just need it to run from User Manager vouchers. Or if I could get some more info on exactly how the trial system works perhaps I can figure out for myself.
I was expecting some answer for this question. I think this would be very useful function and improvement for this hotspot. It is a pity that I am lama and not able to create some script doing this. I hope some more experienced user will try it.
Ivan
I have scripting experience and I am reasonably sure I could script it. However I was hoping that it could become part of a future release, since it seems to be a fairly minor modification of the trial function.
If you are succesfull with the script, could you share it with me on email ivan.heran (at) centrum.cz or will you publish it somewhere?
Thanks.
Ivan
Just made a script to eliminate usage of UM tickets across multiple PC’s (MACs). It’s far from perfect, but it works here.
#   Script name:  BlockSecondMAC
#   To be placed in the Login section of the User Profile (for UM only)
#   Attempt to eliminate use of (UM) ticket users to pass their ticket information to others,
#   thus sharing tickets.
#   The script is not water thight, as it travers through the (UM)session list for getting the current user,
#   another user may have logged in in the meantime, thus giving the wrong user name
#   to this script, which doesn't really harm.  Chanches that a faking user gets missed is minimal.
#   If someone knows how to get the current user in a more eligant way.  Please let us know.
#   In this script the original (paying) user, doesn't get blocked.  A catch 22 situation as he is probably
#   part of the fooling process.   If you want him out too, remove all #22 comments.
:local CurrentUser
:local SessionID
:local FirstMAC 0
:local LastMAC
:local LastI
/tool user-manager session
:foreach i in=[find user!="x"] do={
   :set LastI $i
# LastI now points to last session information
:set CurrentUser [get $LastI user]
:set LastMAC [get $LastI calling-station-id]
:set SessionID [get $LastI acct-session-id]
:foreach i in=[find user="$CurrentUser"] do={
   :if ($FirstMAC = 0) do={
      :set FirstMAC [get $i calling-station-id]
:if ($FirstMAC != $LastMAC) do={
   :log warning "User: $CurrentUser; Session-ID: $SessionID ($FirstMAC and $LastMAC) tempering with network"
#    Cancel user session
   /ip hotspot active
   remove [find user="$CurrentUser"]
#   Remove from active Host list
   /ip hotspot host
#22   remove [find mac-address="$FirstMAC"]
   remove [find mac-address="$LastMAC"]
#   Disable user
#22   /tool user-manager user
#22   disable "$CurrentUser"
#   Block MAC(s)
   /ip dhcp-server lease
#22   remove [find active-mac-address="$FirstMAC"]
   remove [find active-mac-address="$LastMAC"]
#22   add mac-address="$FirstMAC" block-access=yes
   add mac-address="$LastMAC" block-access=yes
#   Remove user cookie
   /ip hotspot cookie
      remove $i
#   Notify End of Script
} else= {
   :log info "User: $CurrentUser; Session-ID: $SessionID ($LastMAC) OK"
thanks don but may i ask,will this affect the users which are not vouchers because i have users who share same username
Dennyglover i have the some question like you. For two mac using one user. Have you fixed it?
