Usermanager CoA not disconnecting users
I have 5rc5 installed using a fairly simple PPPoE setup using UserManager. Everything works ok except for CoA. When I disable a user in user manager, I see the request in the logs on the router board. However, I get the following error
“Hotspot error info debug: Radius Disconnect Request for unknown ip 192.168.101.105”
This is the address assigned by PPoE and I can see it under Active connections in PPP. I don’t have a Hotspot set up.
The user is not disconnected. If I disconnect and try to reconnect, the user is disabled so I know that part works. In the Radius Incoming screen, I see 1 request and 1 Naks. Port is set for 1700.
Any ideas?
CoA is not currently supported
use Radius manager v 3.9 it is support CoA
