Usermanager Database Storage Location
I installed the User Manager on a X86 ROS 5.4 System with 3 Harddrives.
SATA1 = System
SATA2 = UserManager
SATA3 = User Manager Backup
I would now copy the database with a script of SATA3.
I’m not sure where the database is stored. How can I find the Harddrive where the UserManager is stored?
/store> print detail
Flags: X - disabled, A - active
0 name=“user-manager_sata2” type=user-manager disk=sata2 status=backup
1 name=“user-manager_sata3” type=user-manager disk=sata3 status=backup
2 A name=“web-proxy1” type=web-proxy disk=sata1 status=active
WebProxy is not active, the Server is only for the Usermanager.
Why is the status=backup of both Usermanager disks
/store> disk print detail
Flags: S - system
0 S name=“sata1” total-space=240348676KiB free-space=240126448KiB status=ready
1 name=“sata2” total-space=241327600KiB free-space=241089180KiB status=ready
2 name=“sata3” total-space=241327600KiB free-space=241135732KiB status=ready
/tool user-manager> database print
in-use: 100 %
log-size: 17191 kB
log-in-use: 100 %
last-rebuild: apr/18/2011 18:52:13
last-save: dec/13/2011 19:47:28
last-load: apr/17/2011 20:32:29
/file> print detail
0 name=“sata2/lost+found” type=“directory” creation-time=apr/17/2011 21:20:12
1 name=“sata3/lost+found” type=“directory” creation-time=apr/17/2011 21:21:19
2 name=“sata2” type=“disk” creation-time=dec/13/2011 19:25:09
3 name=“sata3” type=“disk” creation-time=dec/13/2011 19:25:09
4 name=“ZPI0-CTLL.key” type=“.key file” size=204 creation-time=apr/19/2011 20:28:02 contents=
5 name=“skins” type=“directory” creation-time=may/30/2011 22:03:34
6 name=“sata2/user-manager2” type=“user-manager store” creation-time=dec/14/2011 10:48:52
7 name=“sata3/user-manager3” type=“user-manager store” creation-time=apr/17/2011 21:34:59
try /store activate user-manager_sata2
