Usermanager history clear 6.33 rc16
Hi, I am testing the new version 6.33 RC16 to try to clean the historic session but I can not properly use the userman / history / clean command. 1000 users currently handle with radius on the same machine as the PPPoE server and each time it restarts take long to respond database. How we can streamline the process of restarting without radius timeout error? Thank you
Hallo joserudi,
i’m not unterstanding. The router is the radius server? Or do you using an external radius server? Do you have an export file for better understanding? We have change to external radius server, because of more than 200 user.
Greetings
Stephan, the ruebenmaster
Yes. The router its radius ser server too. My data base its more than 100 Megabytes. I need to clean sesión user database.
Hallo,
i’ve tested the usermanager in my virtual area with MikroTik x86 6.32.2… no Problems with cleaning, but there are only 200 User. (I take them from the radius server…)
Do you have the user manager in a virtual machine too? try to give more RAM. Sorry, i’vo not more tips at the moment.
Greetings
Please tell me how you clean session logs because I only can remove 1 on 1 withs this option tool/user-manager/session/remove numbers. Thanks
joserudi - Instead of number use [find]. It will execute command on all entries in list;
History clear function does not work with database. If you do something in UM, then you can undo this function by using history. History could grow up to ~150MB in RAM memory. After reboot it still would be clear. Now you can clear this history and get rid of used RAM. For example, if you have a UM on mipsbe with ~100MB of RAM, then there is pretty good chance that after a while device will run out of memory.
I only need clean count session. I have registered two years. I would like to use tool/user-man/session clean but I only can clean one number. Numbers 0-20000 dont work.
Hi
You can use this script
/tool user-manager session remove [/tool user-manager session find where customer =“****”]
instead of **** you must type your customer name.
Don´t work, I need to clear the counter of sessions and just let me clear in 1000 and 1000 there are 30,000 records
This will go like this in v7.1. hope it helps.
/user-manager/session> remove [/user-manager session find where active=no]
Regards
