UserManager Hotspot
Hi
i have a mikrotik router with level6 for use UserManager with unlimited active users.
I have two mikrotik router with level3 for use hotspot with external Server Radius (UserManager of level6…)
In this two last routers, what is the limitation of the active users? if i use external radius server?
thx
Level 3 provides 1 active HotSpot user,
more information about license level restrictions,
http://www.mikrotik.com/software.php
if i use external user manager for login users of my router level4, i need level6 in this router for unlimited users? I need level6 in the two routers?
The difference exists between User Manager and HotSpot server.
User Manager is RADIUS based management system, that provides management for HotSpot, PPP, DHCP, wireless clients.
2.9 User Manager limitations based upon license level (3.0version has some changes, that are given in software page),
level3,4,5 - 10 active sessions;
level6 - unlimited sessions.
HotSpot server provides AAA for clients (authentication, authorization, accounting),
HotSpot client number limitation based upon the license,
level3 -1 user;
level4 - 200 users;
level5 - 500 users;
level6 - unlimited users.
I have same question like that because i’m confused about user manager and hotspot limitation.
If i using hotspot configuration like this :
_____________PC Router 1
____________w/ Routeros
__________Lv.6 (UM active)
______________|
_____|----------------------------------------|
PC Router 2 Lv.4________________PC Router 3 Lv.4
(Hostpot Active,
(Hostpot Active,
using Radius to PC router 1,_______using Radius to PC router 1,
300 users)___________________ >300 users)
Can i still using RouterOS with Lv. 4 in router 2 and router 3 ?
Thx.
(sorry for my bad english).
Level 6 should be used for unlimited active User Manager users.
For the HotSpot server level 4 is enough, when active HotSpot users are <200, you can have as much users as you want on the User Manager. But level 4 sets limit to 200 users for HotSpot.
