UserManager: how to change database size
Hello everybody,
I’m using a Mikrotik RB433UAH with User Manager 6.2 as hotspot. I need to enlarge the database size because after few weeks of usage, the increased recording log, session etc., makes the db 100% full. Every week I have to cancel some old logs and used bills and sessions to free the database.
How can I enlarge the database size?!? I have 485 MB of free disk space and the database is only 841 KB!! the strange thing is that I never set up the database size!
If is helpful I use Winbox 6.2.
Francesco
database size increase automatically,with log and user and session counts.
don’t mistake that database has a predefined size!
exactly!
Thanks for the answer!
Are you sure about the automatic size increase!? With me is not like this. When I arrived at 100%, the database size remains at 841 KB. Last summer I had problem with corrupted database and I would not have the same problem!
To check if I understud properly, in your sistem when you arrive at 100%, you see in the UserManager the number of database size increased?
I tried again and I saw that database size increase automatically!
So now I have 100% full but size increase automatically, and is working fine!
Thank you to everybody.
