Usermanager on Version 5.11
Hello all
today I update my router board to the last version and I want to use the user manager.I was reading the way how it works and I’m confused, does the package will also work on the last version (5.11)?
I have the package installed but it wont open the web site manager using http://ip_router_board/userman
I also change the default port WWW to 81 just in case but nothing.
Can someone give me a tip ?
thanks for all
Check your STORE option under system
should show usermanager active
if not set it active
is there Hotspot server on that mikrotik OS?
I have the module enabled and stangly it can be acessed outside of my lan. In my configuration I have a ppoe client to autenticate from my ISP ADSL and then a NAT to a local lan. today I notice if I try to acess from the Internet side it works!!
I also have hotspot configured internaly, could it be because of this?
if you are connected to hotspot, you can allow direct connection to router by set the address in walled garden.
