usermanager: only one client gets remote ip the others no
Hello
I have used user-manager in other occasions and it has worked with versions routeros before 6.30. I tried to used user-manager again with routeros 6.42.6 and I got an strange behaviour:
All users are registered, in the section ppp - active connections you can see even that it acquires a remote IP but on the pppoe client side does not have IP. Only one user gets a IP.
At client side there is not a dynamic remote address. Only one client adquire remote IP and works fine the others no.
I disabled all firewall rules without success.
Has anyone had this problem?
Thank you in advance
I have the solution:
You must set up a local IP in the defaul profile of the PPPoE server, but a local IP as: abc.def,ghi.jkl not a ip pool with one IP .
