UserManager v5.25 customizable ?
unfortunately I have not found anything that helps to costomize the usermanager v5.25. Acording to wiki , it is no longer possible to customize the User Manager from the version 5.
So my question I desperately need a customized version for example that only the user menu and and sessions menu appears after the I login.
Is there any possibility to hide menu in the usermanger or to edit the underlying html sites?
I am grateful for any help
