UserManager writes very much sectors on memory
Hi, im using 951Ui with 6.12, and have small database UM (<100users). Many bugs of UM doesnt very big problem, main problem that ITS WRITES 50k sectors in 30mins! I turned off all logs from routers, im using scripts that clear logs and active sessions every 3 hours. BUt its still harm my memory. Any solves?
ps Turning off packages>UM shows that problem is right in UM.
Found that UM creates new store on system disk, im thinking problem is here. If i will use usb flash disk, can i change UM store to this USB? (now its unactive)
